Tim's change will appear in the next release of 3.13.
Marty Kraimer
Tim Mooney wrote:
> Andrew Johnson writes...
> > > BAD:
> > > grecord(calc,"$(Ring):BXBCM:TEMPA") {
> > > field(SCAN,"10 second")
> > > field(CALC,"( (A&C) >> 3 ) - B")
> > The thing which I see as significant in these differences is that Ron
> > has taken the literal "3" out of the expression and put it into the
> > input D instead. I have been aware for some time that literals aren't
> > always accepted in CALC expressions (but some work fine -- thats the
> > wierd thing about it). I suspect this may be the area of the problem,
> > but I'm only guessing. It may relate to a literal with an adjacent
> > space, which matches where Rozelle's saw the error being reported.
> Your exactly right.
> Literals (i.e., FLOAT_PT_CONST's in postfix.c) aren't accepted in CALC
> expressions when they are preceded by a space. This is because literals
> are parsed twice, and the second parse doesn't accept spaces. (The first
> parse, which all expression elements undergo, does handle leading spaces.)
> If the line marked below is added to postfix.c, the problem goes away.
> -----excerpt from postfix.c-----------
> long postfix(pinfix,ppostfix,perror)
> case FLOAT_PT_CONST:
> if (!operand_needed){
> *perror = 5;
> return(-1);
> /* add constant to the expression */
> *ppostfix++ = pelement->code;
> pposthold = ppostfix;
> pinfix-=no_bytes;
> >>>-----> while (*pinfix == ' ') *ppostfix++ = *pinfix++;
> while (TRUE) {
> Tim Mooney
> Beamline Controls & Data Acquisition
> Advanced Photon Source
> Argonne National Lab
- Re: Bad CALC record kills IOC Tim Mooney
Re: CPU speed on mv162/167 Andrew Johnson
going mad with Capfast / e2db William Lupton
<1997>
Building extensions with beta10 Bakul Banerjee
<1997>
