Hi Rozelle,
even though it doesn't match the thread's subject exactly - there still is
the problem with dbst and template files:
Since template files contain "$(NAME)" variables, there is no way for dbst
to check fields containing variables for correct syntax and length. Whereas
the macro expansion failure just causes error messages and the syntax check
is not executed afterwards on those fields, an oversized field is cut down
to its maximum length. Therefore you can't use dbst on some template
databases (i.e. templates containing records where fields are oversized due
to variable names being longer than their substitutes).
If the field length cut is part of dbst, this problem might be solved - if
it is part of the dbStaticLib (which dbst uses), I doubt that there's a
solution with reasonable effort.
My guess would be the latter. (Cynics are just disappointed romanticists.)
Ralph
__ Ralph Lange Email: [email protected]
/\ \ WWW: http://www.bessy.de/~lange
/ \ \ BESSY II
/ /\ \ \ Berliner Elektronenspeicherring- Snail: BESSY II
/ / /\ \ \ Gesellschaft fuer Synchrotron- Rudower Chaussee 5
/ / /__\_\ \ strahlung m.b.H. D-12489 Berlin, Germany
/ / /________\ Phone: +49 30 6392-4862
\/___________/ Control System Group Fax: ... -4859
- Re: Bad CALC record kills IOC Rozelle Wright
Re: Bad CALC record kills IOC Andrew Johnson
Re: Bad CALC record kills IOC Marty Kraimer
<1997>
Re: Bad CALC record kills IOC Tim Mooney
<1997>
