1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Boot files for MVME167
To: Marian ZUREK <[email protected]>
Cc: [email protected]
Date: Mon, 30 Jun 1997 09:13:37 +0100
Marian ZUREK wrote:
> I noticed that in my VME 1 min= 90 s !!!
> I already send the question to tech-talk and recived answer (THANKS)
> saying that I have to recompile the base with small modifications.
Hi Marian,
I'm not sure if this is your problem, but if your mv167 clock is running
slightly slow (1 minute really takes 80 seconds rather than the 90 you
mentioned) you shouldn't have to rebuild anything to get it running at
the right speed.  The SPECIAL CONSIDERATIONS section of the vxWorks BSP
man page 'mv167' explains how to set the clock rate in the non-volatile
RAM, which you do once for each CPU card. Just type the following at the
vxWorks shell prompt:
  -> m 0xfffc00fe
  fffc00fe:  0000-21ee
  fffc0100:  0000-.
  value = 1 = 0x1
Then after you next reboot, the clock should run correctly.  If you
don't set this, the BSP assumes it is running on a 25MHz CPU so
everything happens extra slowly.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
CPU speed on mv162/167 Ralph Lange
Boot files for MVME167 Marian ZUREK
Prev: [no subject] meyer
Next: Re: IOC hangs (still) Marty Kraimer
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Boot files for MVME167 Marian ZUREK
Next: CPU speed on mv162/167 Ralph Lange
