1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: MEDM Print
To: [email protected], [email protected]
Cc: [email protected]
Date: Fri, 27 Jun 1997 08:36:32 -0500
Ron Chestnut writes:
> The MEDM "Print" output makes the postscript printers unhappy. I am
> unable to find information on where the temporary file is and/or how
> to not have the file deleted. Also, I'm guessing that PSPRINTER
> and/or PS_PRINTER serve to direct the printout here or there.
    The files are in /tmp/medm.xwd*.  To have the file not deleted,
you need to modify the code.  The appropriate place is is printUtil.c
in the graphX/printUtils directory.  Do something near the bottom of
the file like:
#define DEBUG_PRINT
#if DEBUG_PRINT == 0
    strcpy(commandBuffer,"lp -d$PSPRINTER ");
    strcat(commandBuffer, psFileName);
    system(commandBuffer);
  /* Delete files */
    strcpy(commandBuffer,"rm ");
    strcat(commandBuffer,newFileName);
    strcat(commandBuffer,psFileName);
#endif
     MEDM requires the PSPRINTER environment variable to exist for
printing to work.  It should be set to a printer name for a printer
that accepts Postscript.
     There is also the Printer Setup... option under the File menu.
Invoking this will cause the environment variable to be set to the
printer of your choice (in the MEDM shell).
     I am not sure what you mean by "unhappy".  There will be some bug
fixes related to printing from 24-bit displays in the next release.
However, you still get somewhat reasonable output without them.
Otherwise, to my knowledge, printing works well.
     Good luck.
	-Ken
Prev: Re: Statically Built MEDM and GDCT for HPUX9.05? Ralph Lange
Next: Statically built MEDM/GDCT, xfdApp distribution Bakul Banerjee
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: MEDM Print Ron Chestnut
Next: Statically Built MEDM and GDCT for HPUX9.05? Dave Reid
