1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: NFS vxWorks Access Rights
To: Ralph Lange <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 24 Jun 1997 11:38:55 +0100
Ralph Lange wrote:
> I'm using an absolute symbolic link, i.e. simple string replacement when
> processing the link would result in the correct path. (Still the problem
> might be due to the file system crossing.) And - I forgot to tell -
> reading a file works perfectly, just writing produces the error.
> Do you think this fits the FAQ explanation?
I don't.  I wondered whether it might be that you're mounting a
filesystem called '/' and '/something', but if you get reads working
from the '/something' filesystem and you are sure these are through nfs
and not via rsh or ftp then that's unlikely.
What does nfsAuthUnixShow tell you about the uid/gid/gids of the target?
Are they actually set to who you think they are?  If not, you might
expect that behaviour if it's allowed read-only access to the directory.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Re: NFS vxWorks Access Rights Ralph Lange
Prev: Re: NFS vxWorks Access Rights Ralph Lange
Next: Re: NFS vxWorks Access Rights Ralph Lange
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
