1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: NI-1014 help needed
To: [email protected]
Cc: [email protected]
Date: Wed, 18 Jun 1997 09:11:10 -0700
> '147 cards use the VMEchip, '167 cards have the VMEchip2 which provides
> more facilities.
> You may be able to get by without changing the '147 BSP itself, you just
> need to write some code which stuffs the right values into the VMEchip
> registers sometime before iocInit (this will be non-portable code which
> will obviously only work on a '147).
Bingo!  You're right!  Don't know how I forgot after chasing some problems
with the original VME chip on the '147. Hmm - they may have been dma or
interrupt-queuing problems.  I think they didn't show up when there was only
one source for the requests, hence no contention.
I think I'm suffering from brain-rot.
-bill
Prev: Re: NI-1014 help needed Andrew Johnson
Next: BUG(?) in AR.c and AR_cmd.c Noboru Yamamoto
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: NI-1014 help needed Josep A. Perlas
Next: Re: NI-1014 help needed Ned Arnold
