1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: NI-1014 help needed
To: Bill Brown <[email protected]>
Cc: [email protected], [email protected], [email protected], [email protected]
Date: Wed, 18 Jun 1997 16:51:10 +0100
Bill Brown wrote:
> I think both cpus ('147 & '167 use the VME chip, altho I can't be sure that
> there isn't more than one version of it, and I'm not sure that the registers
> are used in the same manner.  Perhaps a comparison of the appropriate parts
> of the sysLib.c files may be helpful.
'147 cards use the VMEchip, '167 cards have the VMEchip2 which provides
more facilities.
You may be able to get by without changing the '147 BSP itself, you just
need to write some code which stuffs the right values into the VMEchip
registers sometime before iocInit (this will be non-portable code which
will obviously only work on a '147).
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Re: NI-1014 help needed Bill Brown
Prev: Re: NI-1014 help needed Bill Brown
Next: Re: NI-1014 help needed Bill Brown
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: NI-1014 help needed Josep A. Perlas
