1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: head & tail patches to vxWorks interrupt service routines?
To: <[email protected]>, "Guy Jennings" <[email protected]>
Date: Thu, 12 Jun 1997 12:52:12 -0600
> Can any of the vxWorks gurus out there tell me if it is possible to do
> a head or a tail patch to a vxWorks interrupt service routine.  We want
to
> hook in to the serial input interrupt and then pass on the servicing to
the
> existing service routine.
Yes, this is possible. After loading EPICS core run "veclist" to find out
the symbol name of the routine that is attached to the interrupt in
question.
Use intConnect() (C source code) or intVecSet() (assembler) to attach
your code (which will call the original ISR attached to the interrupt).
Note that there are only a limited set of vxWorks system calls that can
be safely invoked from within an ISR.
Jeff
Prev: Re: head & tail patches to vxWorks interrupt service routines? Benjamin Franksen
Next: Re: IOC hangs (scanOnce crashes) Ralph Lange
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: EPICS Software Distribution back for business Bakul Banerjee
