1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IOC hangs (scanOnce crashes)
To: [email protected]
Date: Tue, 10 Jun 1997 12:55:23 -0500
Ralph Lange wrote:
> The periodic scan tasks ARE automatically restarted. (See line 539 +-20 of
> dbScan.c) Looks safe to me in that case. Generally I would agree with you.
In my version I see
near top of dbScan.c
int volatile scanRestart=FALSE;
Then later:
static void wdPeriodic(long ind)
    scan_list *psl;
    if(!scanRestart)return;
Thus tasks are not restarted. Many things could go wrong.
For example a task is likely to have records locked.
Restarting will merely hide original problem and cause
really strange behavior.
> > If you get a stack trace of crashed scanOnce task it should help.
Note that on ioc onceTask is given name scanOnce. This is confusing.
> We're trying to catch the task that is calling scanOnce() to see where the
> crap comes from. I think the onceTask itself doesn't do too much
> interesting things - it just reads from the ring buffer and calls
> dbScanLock without checking the validity of the precord it got from the
> buffer - then dies.
Note that onceTask scans a record. Since records can be linked,
this means an arbitrary number of records can process. This means
an arbitrary set of record/device/driver support can be executed.
Marty Kraimer
Re: IOC hangs (scanOnce crashes) Ralph Lange
Prev: Re: copying of monitored data Jeff Hill
Next: ACS Microstepper Drives Guy_Jennings
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: IOC hangs (scanOnce crashes) Ralph Lange
Next: Re: IOC hangs (scanOnce crashes) Ralph Lange
