Enclosed is a sample python program which displays windows on X-terminal.
Each window has a slider and a label which are both connected to EPICS channel.
I also enclosed ca.py which implements EPICS channel class in python. ca.py
uses _ca module which are written in C. Python can retuns any value, includig
list called tuple in Python, as a return value of get().
Development status is quite preliminary but(or because of it) I appriciate
your comments.
Thank you,
Noboru Yamamoto
KEK, Accelerator Lab.
Noboru Yamamoto
KEKB Accelerator Control Group
KEK, JAPAN
Fax:+81-298-64-0321
Tel:+81-298-64-5309
e-mail:[email protected]
import ca
from Tkinter import *
class Simple(ca.channel,Frame):
def __init__(self,name,master=None,*cnf):
Frame.__init__(self,master)
self.pack(expand=1,fill='both')
ca.channel.__init__(self,name);self.pendio(0.1)
self.get();self.pendio()
l=Label(self,text="CA readback")
l.pack()
s=Scale(self,orient="horizontal",label=name)
s.pack(expand=1,fill='x')
s.set(self.val)
b=Button(self,text="Quit",command=self.quit,text=`self.val`)
b.pack()
self.s=s
self.b=b
self.l=l
self.monitor(self.update_scale)
self.monitor(self.update_label)
self.pendio()
self.s.config(command=self.scale_change)
def repeater(self): # in-efficient compared to alarm routin in C
self.pendio(0.0005)
self.after(20,self.repeater)
def scale_change(self,arg):
v=self.s.get()
if( v <> self.val):
self.put(v)
self.pend_event(0.0005)
def update_label(self,val):
self.val,self.stat=val
self.l.config(text=`self.val`)
def update_scale(self,val):
self.s.set(self.val)
if(__name__ == "__main__"):
Simple("FFTB:WS2",master=Tk())
Simple("FFTB:WS3",master=Toplevel())
Simple("FFTB:WS1",master=Toplevel()).mainloop()
import _ca
pendio=_ca.pendio #export pendio
pend_event=_ca.pend_event
flush_io=_ca.flush
class channel:
def __init__(self,name):
self.chid=_ca.search(name)
self.val=0.0
self.evid=[]
def __del__(self):
self.clear_monitor()
_ca.clear(self.chid)
_ca.pendio(1.0)
def get(self):
_ca.get(self.chid, self.update_val)
def put(self,val=None):
_ca.put(self.chid,val,self.val)
def monitor(self,callback=None):
if(not callback):
raise No_Callback_Error
self.callback=callback
self.evid.append(_ca.monitor(self.chid,self.callback))
def clear_monitor(self,evid=None):
if(not evid):
for i in self.evid:
print "clearing evid",i
_ca.clear_monitor(i)
self.evid=[]
else:
_ca.clear_monitor(evid)
def pendio(self,wait=0.0005):
_ca.pendio(wait)
def pend_event(self,wait=0.0005):
_ca.pend_event(wait)
def flush(self,wait=0.0005):
_ca.flush(wait)
def update_val(self,valstat):
self.val,self.status=valstat
def exec_callback(self,val):
self.callback(self,val)
- Re: EPICS Channel Access in Python. Nick Patavalis
Re: EDD/DM: Passing multiple arguments for color rule definition ? Deb Kerstiens
Continous feedback control for stepper motors Benjamin Franksen
<1997>
Re: EDD/DM: Passing multiple arguments for color rule definition ? Anna M. Estes
<1997>
