> Hi,
> In the EDD/DM I need to implement color rule which represents the
> highest alarm severity of two channels.
> Then I didn't found how to pass two or more arguments to the rule (is it
> possible at all ?)
> Any ideas welcome.
> Thanks in advance,
> Marian
> Marian Zurek
> CERN/ECP-CO
Hello Marian,
Yes, it is possible to pass more than one argument. However,
you can't directly compare one alarm severity to another since
the right hand terms (the terms following the comparators)
are basically constants.
In the modify property page for the item in the "color rule
arguments" field, you can enter something like:
A=chan1.SEVR, B=chan2.SEVR
Your color rule definition could be something like:
$(A) equals MAJOR and
$(B) less than 2 use <A>B color>
$(A) equals MINOR and
$(B) equals NONE use <A>B color>
$(B) equals MAJOR and
$(A) less than 2 use <B>A color>
$(B) equals MINOR and
$(A) equals NONE use <B>A color>
Note that the color is selected on a "first match" basis,
Also comparisons are done based upon the type of entry, i.e.
if a string is in the third column, the value of the first
column will be compared using a string compare and a numerical
compare will be done otherwise. It's awkward since you have to
define all possible comparisons separately.
Let me know if you have more questions.
Deb
p.s. For the next generation EPICS gui, we plan to implement a more
flexible expression evaluator for color rules, visibility,
and value conversion.
Deb Kerstiens [email protected]
Phone (505)667-3396
LANL AOT-8,MSH820 PO Box 1663, Los Alamos, NM. 87545
Anna Estes
Computer Sciences Corporation
NASA Langley Research Center
[email protected]
(757) 766-8266
- Re: EDD/DM: Passing multiple arguments for color rule definition ? Marian ZUREK
Re: EDD/DM: Passing multiple arguments for color rule definition ? Deb Kerstiens
please ignore my last email Anna M. Estes
<1997>
High Current Motors and ACS step/pac laurence lurio
<1997>
