1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: get_precision problem
To: [email protected]
Cc: [email protected], [email protected]
Date: Wed, 21 May 1997 16:46:15 -0500
Richard Dickson reported:
    TJNAF uses a locally developed record whose get_precision function
relies on the passed paddr->pfield to point to the field for which
precision is being requested.
In 3.13 there is a better way to determine the field.
A new routine
int dbGetFieldIndex(struct dbAddr *paddr);
is available. In addition the generated .h file
has a #define for each field. For example
the aiRecord.h has definitions:
#define aiRecordNAME    0
#define aiRecordDESC    1
#define aiRecordASG     2
#define aiRecordSCAN    3
#define aiRecordPINI    4
#define aiRecordPHAS    5
#define aiRecordEVNT    6
#define aiRecordTSE     7
#define aiRecordTSEL    8
#define aiRecordDTYP    9
#define aiRecordDISV    10
Thus you can use statements like
  ind = dbGetFieldIndex(paddr)
   if(ind==aiRecordVAL) ...
or use switch statements, etc.
Note that dbGetFieldIndex does NOT use pfield to determine
the index.
Does this solve your problem?
Marty Kraimer
Prev: Re: 3.12.2 GetRel command Rozelle Wright
Next: stripTool Documention Graham Waters
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: get_precision problem Marty Kraimer
Next: Capfast Bob Dalesio
