1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MEDM upgrade message
To: EPICS tech-talk <[email protected]>
Date: Thu, 24 Apr 1997 14:45:04 +0100
Steve Hunt wrote:
> Could the JDM become the common platform ?
> why not use that as the DM for NT ?
and Chip Watson responded with his usual enthusiasm!
The problem I see with JDM at the moment is that (I believe) it relies
on a CDEV gateway running on the www-server.  This will be fine for some
sites, but additional complexity and slowness for others.
Bearing in mind Chip's comments on the speed of Java JDM might become a
resonable standard DM for use with NT, but I'd want to be able to
connect to IOCs directly using Channel Access, without having to set up
a WWW-server *and* a CDEV gateway.  If the collaboration wants a
standard Display Manager under NT it's going to have to support Channel
Access directly IMHO or someone will write a program that does.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
RE: MEDM upgrade message Steve Hunt
Prev: Re: MEDM upgrade message Chip Watson
Next: undefined symbol Russell J. Page, Sr.
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
