1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: gnu cross-compiler problem
Cc: [email protected]
Date: Tue, 15 Apr 1997 17:30:10 -0700
Andrew Johnson wrote:
> Strictly speaking Jeff's comment about making these items volatile is
> incorrect, because I know they're all in a PROM on the IPAC module and
> hence cannot change at run-time.  However this does actually solve the
> problem because gcc cuts out the optimisation. Change the beginning of
> the ipmCheck routine by adding the volatile keyword to the definition of
> id to produce the following:
> int ipmCheck (
>     ushort_t carrier,
>     ushort_t slot
>     volatile ipac_idProm_t *id;
>     char dummy;Q
Well, thanks to everybody for the prompt replies. The volatile keyword
did the trick.
Additional note:
We got our CAN-bus running today. We are using the TIP810 industry pack
on an MV162 (Andrew's documentation says this driver is not tested, as
he runs carrier boards). We had to add a call to ipmIrqCmd to enable the
ipic interrupt on the MV162.
				- rolf -
: Rolf Keitel                |    [email protected]           :
: TRIUMF                     |    Tel: (604) 222-7453      :
: 4004 Wesbrook Mall         |    Fax: (604) 222-7307      :
: Vancouver, B.C., V6T 2A3   |    www.triumf.ca            :
gnu cross-compiler problem Rolf Keitel
Re: gnu cross-compiler problem Andrew Johnson
Prev: Re: gnu cross-compiler problem Steve Lewis
Next: [no subject] Bill Stewart
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: gnu cross-compiler problem Andrew Johnson
Next: Re: gnu cross-compiler problem Steve Lewis
