1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: gnu cross-compiler problem
To: Rolf Keitel <[email protected]>
Cc: andrew_johnson <[email protected]>, [email protected]
Date: Tue, 15 Apr 1997 07:47:15 -1000
Rolf Keitel writes:
 >  > make
 > /usr/local/gnu/solaris.68k/bin/cc68k
 > -B/usr/local/gnu/solaris.68k/lib/gcc-lib/
 >   -c -O -W -m68040 -nostdinc -DV5_vxWorks -DvxWorks -DTARGET_OS=vxWorks
 > -DCPU=MC68040
 >   -DV5_vxWorks -DCPU_FAMILY=MC680X0  -I../src -I../epicsH
 > -I../epicsH/rec
 >   -I../vw/h ../src/drvIpac.c
Rolf,
	You might try forcing the compiler to turn all optimization
off by using the -O0 flag. I found that this was required to make some
driver code work.
Aloha,
	Peregrine
Peregrine M. McGehee			http://www.cfht.hawaii.edu/~mcgehee
Telescope Control Systems Group 	Canada-France-Hawaii Telescope
(808) 885-3178				P.O. Box 1597, Kamuela, Hawaii 96743
gnu cross-compiler problem Rolf Keitel
Prev: gnu cross-compiler problem Rolf Keitel
Next: Re: Buffer copying? Jeff Hill
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: gnu cross-compiler problem Andrew Johnson
