Hello Andrew,
I am trying to get our CAN-bus system going and ran into the following
problem with our
GNU cross-compiler. I am running Solaris 2.5, and the cross-compiler
version is:
> cc68k -v
Reading specs from
/usr/local/gnu/solaris.68k/lib/gcc-lib/m68k-wrs-vxworks/cygnus-2.2.3.1/specs
gcc version cygnus-2.2.3.1
The offending code is in drvIpac.c in the routine ipmCheck:
if (id->asciiI != 'I' || id->asciiP != 'P' || id->asciiA != 'A' ||
id->asciiC != 'C')
return S_IPAC_noIpacId;
return OK;
This piece of code returns S_IPAC_noIpacId.
A control printout of the involved variables shows that the return
should be OK:
printf("\n%x: %c %c %c %c\n", id, id->asciiI, id->asciiP,
id->asciiA, id->asciiC);
printf("%x %x %x %x\n", id->asciiI, id->asciiP, id->asciiA,
id->asciiC);
printf("%x %x %x %x\n", 'I', 'P', 'A', 'C');
-- start of control printout
fff58080: I P A C
49 50 41 43
49 50 41 43
ipmCheck returns 2580006
value = 39321606 = 0x2580006
-- end of control printout
If I change the code to individual comparisons,
the return is OK:
if (id->asciiI != 'I')
if (id->asciiP != 'P')
if (id->asciiA != 'A')
if (id->asciiC != 'C')
return OK;
If I define intermediate variables, the return is also OK:
uchar_t I, P, A, C;
I = id->asciiI;
P = id->asciiP;
A = id->asciiA;
C = id->asciiC;
id->asciiC != 'C')
return OK;
My make file produces the following compiler command line.
> make
/usr/local/gnu/solaris.68k/bin/cc68k
-B/usr/local/gnu/solaris.68k/lib/gcc-lib/
-c -O -W -m68040 -nostdinc -DV5_vxWorks -DvxWorks -DTARGET_OS=vxWorks
-DCPU=MC68040
-DV5_vxWorks -DCPU_FAMILY=MC680X0 -I../src -I../epicsH
-I../epicsH/rec
-I../vw/h ../src/drvIpac.c
Is this a known problem?
- rolf -
: Rolf Keitel | [email protected] :
: TRIUMF | Tel: (604) 222-7453 :
: 4004 Wesbrook Mall | Fax: (604) 222-7307 :
: Vancouver, B.C., V6T 2A3 | www.triumf.ca :
- gnu cross-compiler problem Peregrine McGehee
- Re: gnu cross-compiler problem Andrew Johnson
Buffer copying? Peregrine McGehee
<1997>
Re: Buffer copying? Jeff Hill
<1997>
