Chris
you might find some information @ CERN they have to solve the same problems for their new
LHC detectors:
"[email protected]" Fabien Perriollat
"[email protected]" Helfried Burckhart
My approach would be to reduce the data flow at the source. I.e. use local (simple) CAN
controllers with embedded ADCs to read the voltage and send monitors on change to the IOC.
The IOC itself could reduce the data flow by setting propper limits to the monitors.
You might also want to combine the readings from one 1HV channel with its readings from 48
PMTs to one EPICS record which will fire a monitor whenever one of the 48 PMTs changed.
This would lead to about 3'000 records which an IOC can easily handle. Taking into account
that your readout scan time is really slow you could connect 100 CAN nodes to one CAN
controller on a dedicated VME CPU (i.e. 162) which can handle four of these. This CPU will
handle the IO-interrupt and communicate to the main CPU over VME which runs the EPICS
database. Each of the CAN nodes will handle the readout of 8 HV channel with the
associated 48 readouts. In this case each readout could keep its own CAN -ID or you could
combine the 48 readings into one CAN object that you transfer to your dedicated EPICS
record for the 48 readouts.
Reasonable approach?
Matthias
Time granularity in archive data streams Matt Bickley
Compilation error in EPICS extension Janet B. Anderson
<1997>
Problem of monitoring 15,000 channels within EPICS Chris Witzig
dm / medm applet? William Lupton
<1997>
