1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problem of monitoring 15,000 channels within EPICS
To: [email protected]
Date: Mon, 24 Mar 1997 12:36:26 -0500 (EST)
Hallo,
I am Chris Witzig and work for the Phenix experiment
at RHIC. We have the following problem to solve within
EPICS and are wondering whether some EPICS expert out
there knows an elegant (i.e. good and cheap) solution:
Our PbSc calorimeter has 15,000 PMTs. The HV is multiplexed
due to the high number of channels (1HV channel
is multiplexed to 48 PMTs).
For monitoring/debugging purposes the PbSc group would like to
monitor the current for every tube at the base.
The readback frequency is low (once every few minutes is
ok),  the accuracy doesn't need to be good  (less than 10 bit
good enough). Price is an issue of course.
Due to the high channel count we would like to
multiplex these 15,000 channels also for this monitoring
readback (1 EPICS readable scanning ADC is able to
monitor several PMTs and EPICS is able to select which one).
Has anybody ever implemented such a system within EPICS?
Comments and suggestions are highly appreciated.
Best regards
Chris Witzig
email: [email protected]
Prev: WAIT record? Garrett D. Rinehart
Next: dm / medm applet? William Lupton
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Supported Hardware Steve Lewis
Next: RE: Problem of monitoring 15,000 channels within EPICS Matthias Clausen DESY -MKS-2/KRYK-
