1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VxWorks file i/o problem
To: Len Lawrence <[email protected]>
Cc: tech-talk EPICS <[email protected]>, Sean Prior <[email protected]>
Date: Wed, 05 Mar 1997 09:43:28 -0700
Len Lawrence wrote:
> Sorry folks for introducing a VxWorks query, but after two weeks of
> frustration trying to make the EPICS log server work I have returned
> to simple file i/o (fopen, fprintf, etc) on an mv167 IOC running
> VxWorks 5.2.
What were the problems that you were having with the log server?
What version of EPICS are you using?
> It would be useful to be able to examine the output on
> the fly but no file ever appears until fclose is called.
> fflush does
> not do the business.
This is a feature of the vxWorks FTP file system. The vxWorks
NFS client does not suffer from this limitation.
Will you have multiple IOCs logging to the same file?
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Re: VxWorks file i/o problem Chip Watson
VxWorks file i/o problem Len Lawrence
Prev: Re: VxWorks file i/o problem Philip Taylor
Next: Re: VxWorks file i/o problem Chip Watson
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
