1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Odd behavior in snc 1.8.3
To: [email protected]
Date: Mon, 10 Feb 1997 16:27:20 -1000
Using SNC version 1.8.3 (old!) I find that the following SNL code:
evflag domeCmd;
string domeCmd;
float domePos;
when (efTest(efDomeCmd) && (sscanf(domeCmd, "DOME %lf", &domePos) == 1)) {
	<stuff>
} state check_cmd
is transformed (via snc) into:
# line 277 "../tcsiiisim.stpp"
if (efTest(efDomeCmd) && (sscanf(domeCmd , "DOME %lf" , TRUE & domePos)  == 1))
   ss_ptr->next_state = 1;
   ss_ptr->trans_num = 2;
   return TRUE;
At which point gcc complains about the third argument to sscanf not
being a pointer. I guess something is triggering the default case in
the expr_exp() procedure [gen_ss_code.c] to produce the unwanted
"TRUE".
Aloha,
	Peregrine
Prev: RE: mbbiDirect and mbboDirect changes in r3.13x Eric Bjorklund, NPSM
Next: RE: mbbiDirect and mbboDirect changes in r3.13x Ned Arnold
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: bug report (little endian and IEEE FP) Jeff Hill
Next: Re: Odd behavior in snc 1.8.3 Peregrine McGehee
