Richard Wolff wrote:
> Hmmm...looks like a suitable challenge here. I'll try to do something
> on this with Python in the next week, after the current bits of chaos
> around here are scheduled to subside.
If you get started on this we should make sure that you are working
with the same version of EPICS as Kay. We have recently
(this fall) moved some of the shell based stuff into gnu make.
Sorry to go ahead with a perl prototype prior to the end
of the discussion. We must move quickly because Kay's last
day here is Feb 21 (after which he is returning to Germany)
- and he is the only one of us that really knows perl at
this point. Also, if this change makes it into 3.13 then
the NT port will be much easier to install, and we are very
close to making an official release of 3.13.
At this point there are a fairly small number of scripts that
need to be replaced. As I recall Kay mentioned that he has
3 days into this so far.
I think that it is safe to say that the advantages of object
oriented programming are most relevant to large projects with
many lines of code. Do you see a practical advantage of python
over perl considering that most of the projects written in
scripting languages are likely to be smaller in scope?
Can anyone else comment on there preference/tolerance/revulsion
of/for python before Richard gets started?
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
- Re: Make, Scripts, Shell, Perl!? Richard Wolff
[no subject] W.-D. Klotz
<1997>
<1997>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
