1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Make, Scripts, Shell, Perl!?
To: [email protected]
Date: Thu, 23 Jan 1997 12:33:48 -0800
I personally have never liked the the current method of using shell scripts
to build source. It really makes the build process too unix-centric. Granted
with added expense and effort you can make a lot of systems look like unix
but that seems the wrong approach if your goal is system independence. Perl
is available on most systems and can certainly do anything that the C shell
can.
Chris
Prev: XYCOM 566 Help Alicia Hofler
Next: Joerger `VDACM' 8ch/16bit waveform generator SARKAR
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Make, Scripts, Shell, Perl!? Marty Kraimer
Next: Re: Make, Scripts, Shell, Perl!? Noboru Yamamoto
