g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Bug in Burt
To: tech-talk@aps.anl.gov
Date: Fri, 17 Jan 1997 12:29:22 -0800
-- In function BurtPreprocessFile() 'burtcommon.cc'
PROBLEM:
	The character buffer 'system_command' is allocated a size
	which assumes the default preprocessor args 'cc -C -E'
	If the string BURT_PREPROCESSOR defined in the make file
	is longer than the default a buffer overflow occurs. This
	is manifested in a crash when 'getc' is executed. (at least it does
	when compiled with gcc 2.7.2)
SOLUTION:
	replace the line:
	nbytes = strlen("cc -C -E ") + strlen(filename) + strlen(newfilename);
#ifdef BURT_PREPROCESSOR
	nbyte = strlen(BURT_PREPROCESSOR) + etc/etc
#else
	nbytes = strlen("cc -C -E ") + etc/etc
| Graham Waters, Control System Eng          Internet: waters@triumf.ca |
| TRIUMF --- University of British Columbia,	phone: (604)-222-1047   |
| Vancouver, BC, Canada                           Fax: (604)-222-7307   |
|                                                http://www.triumf.ca   |
Prev: Re: Joerger VSC16/8 scaler support SARKAR
Next: Test Russell J. Page, Sr.
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: video digitizer David Hardy
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
