g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Fieldbus's
To: tech-talk@aps.anl.gov
Date: Thu, 9 Jan 1997 14:33:53 -0500 (EST)
>> Hello All,
>>       We have been looking at fieldbus's to replace the BITBUS for
>> new projects at Bates.  Both PROFIBUS and CAN look promising.
>> Can someone comment on the advantages or disadvantages of PROFIBUS
>> verses CAN?
>> Thanks,
>> Coles Sibley
>Hi Coles,
>  We're in the same situation. Please keep us informed on what you
>  find out. Currently, we are investigating the Universal Serial Bus
>  that is coming out for the PC's to see if it is applicable as a
>  field bus. It will be cheap, well debugged, well supported, and
>  well documented (unlike Bitbus). Not sure if it will work over
>  fiber ...
>  	Keep in touch -
>  		Ned
Hi Ned,
Have you looked into the Foundation Fieldbus?  The Foundation Fieldbus
is the result of a merger between the Interoperability Systems Project
ISP and WorldFIP.  It's a very new standard in the US and is in the
process of being standardized worldwide(?) as the ISA/IEC SP50 specification.
speed (H2) @500m	2.5 Mbit
data per packet		1000 bytes
(lots more data at www.fieldbus.org/business/information/ffmain.html)
commercial support
	Several companies have commercial developers packages
	available but commercial availability of remote IO is
	not expected until later this year.
Coles
Prev: Re: flaky IOC problems at Jefferson Lab watson
Next: Re: PROFIBUS vs CAN John Maclean
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Prev: PROFIBUS vs. CAN SIBLEY
Next: edd 2.2, Solaris 2.5 and Sun patch 103210-09 Andrew Johnson
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
