Hello all,
After some off line discussion about this request for a modification
to the ca client API allowing the record type and name to be queried.
we have come up with the following potential solution.
A new data type could be added to the dbr_XXX types in db_access.h
and a new PV attribute application type could be added to the
gdd self describing data class as follows:
gdd ca client EPICS DB subsystem
gddAppTypeClassName DBR_CLASS_NAME the record type
gddAppTypeInstanceName DBR_INSTANCE_NAME the record name
This would allow an application to directly query an EPICS
database PV's record name and type. Other subsystems underneath
of the CA server would of course implement different mappings for
these attributes.
The PV model present in the ca client API and the database
access API has had some success fostering a tool
based approach. Currently, we have two types of PVs:
o Analog with limits, units, etc
o Enumerated with strings associated with each state
I suspect that in many cases the users need to know the record name
only because they need to modify PV attributes such as the units
and the limits by poking directly in record specifc fields? If so,
perhaps the immediate need is to provide write access to the
compound DBR_XXXX types from the ca client API. This will perhaps
avoid changes in application level code when the record type
changes for a particular record instance in the database.
Any comments?
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Re: RTYP ? Pete Jemian
Re: frc64/frc604RT performance KAJI Masahiro
<1996>
Transmitter controls suggestions? SIBLEY
<1996>
