hello all,
As requested a patch for 3.12.2 has been prepared that fixes the
following two problems:
Bug number (1)
Symptom: Error messages about invalid sync group id when
running CA client side test "acctst.c". This problem has
been observed with gcc 2.7.2 and with a recent version
of the VMS C compiler when optimization is enabled. This
problem has not been observed in code compiled by the gnu
C compiler supplied with vxWorks 5.2 or with sun pro {4.1,
4.0.1}.
Fix: Removed use of "const" in the CA client API typedef
"CA_SYNC_GID" in cadef.h.
Bug number (2)
Symptom: CA client lib incorrectly prints disconnect message
when a connection to a particular IOC is deleted because
the last channel using that connection was deleted (by
the client side tool).
Fix: Dont print a disconnect message in this particular situation.
The above changes have been committed to the 3.12.2 CVS branch
at APs.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Re: RTYP ? Tim Mooney
Re: RTYP ? Gabor Csuka
<1996>
Re: Training laurence lurio
SLC 500 support under R3.13Beta4 S. Joshua Stein
<1996>
