1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Hardware Configuration
To: [email protected]
Cc: [email protected] (Gabor Csuka)
Date: Thu, 14 Nov 1996 16:08:42 +0100 (MET)
Greetings,
Comments for 'HARDWERE RECORD' an other wiew:
1) The current Epics database structure is a nice mapping of the
induvidule points into 'records' .
2) There is no mapping of the hardware configuration , what
was existing: module_types.h
The problem what we try to solve:
- a new (optional) mapping of the IOC hardware (e.g VME or PCI bus)
  configuration
	* This is the minimum for handling a various hardware
	  configuration and useing one compiled Epics IOC.
	* A part of it must be know only the 'driver' -
		(e.g. VME address space, int. vector)
	  an other part must be known by the 'channel'
	  records (e.g. RAWH,RAWL or MASK for BI/BO)
- make the 'hardware' dependent parameters visible and
  (for the future) runtime configurable.
- adding spaceholder for the prototype modules which are
  connected via (e.g. ) field bus to the IOC. (e.g. CAN
  moduls )
	* One way (see the mail from Ralph BESSY) mapping
	  each induvidual module for an object in IOC
	* Or useing a 'prototype' object - which only
	  a spaceholder of the 'type'
- handle and support a more configurable devices such as
  BE490 adc.
	* this device can handle ap to 8 channel, has
	  27 configurable general parameters and 16
	  configurable parameter / channel (!)
An approach for the last item. (This is under construction !)
1. The hardwere will be mapped as a record
2. The record (BE490) will be new, which contains
   the all 27 + 8 * 16 parameter field. (This is a spaceholder
   function)
3. At the record initiate time will be the hardwere initiated
    * By the way, how can I force the iocInit to initiate this
      record before the ai recrds pointing this device will be
      initiated ?
    * At the initiate time the record try to get the static
      information (such as IO address space Interrupt level,
      and when it is faild - usese the (DCT) configured
      parameters.
4. The record has 8 'LINK' pointing the correspondent ai
   records.
Which answere can be added useing hardware record ?
1. The proposed hardware record covers the past and
   not the future requiroments.
	That is meaning it is nicely fitted an existing hardwares
	but does not cover the problem of the 'filed bus' modules,
	and does not cover the intelligent devices.
2. The configurable parameters are visiable (dct)
   and CA.
3. There are the possible run time reconfiguration
   useing the existing (CA/dbAccess) mechanism.
I hardly supported the hardware record with the following
requiroments.
The all 'hardware record' must be initiated eralier than
the connected 'channel' records and earlier then the dev/drv
which is connected to this one.
With other words, I prefer the following sequence:
	1. The hw record applies his 'global' parameters -
	   if it does not success - uses his configured ones.
	2. and make a registration to reserve them. (Don't forget,
	   maybe some resource has been allocated before Epics was
	   downloded)
	3. the device/driver support module gets the parameters from
	   the hw record and makes the initialisations work.
	4. When all 'hw' record initiation has been finished:
	   can start the 'rest'.
I don't think so that we can cover the all problems
useing a common 'hardware record' but it is high time
to start this work.
Gabor Csuke
DESY, Germany
Re: Hardware Configuration watson
Prev: alarm-handling questions William Lupton
Next: RTYP ? Pete Jemian
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Hardware Configuration Ralph Lange
Next: Re: Hardware Configuration watson
