g+
g+ Communities
Argonne National Laboratory
1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: R3.13 Update
To: tech-talk@aps.anl.gov
Date: Tue, 29 Oct 1996 08:43:20 -0600
Last week tuesday we had a chance to bring up several APS Linac
IOCs under 3.13. Almost everything worked. We had just two hours
to try things. This was just before starting a scheduled 6 week
shutdown. The test gave Ned Arnold, the Application Developer
responsible for the Linac, confidence that he can convert to 3.13.
This is a major success since the Linac was the first and thus oldest
system at APS to start commissioning. Thus the special record
and device support was originally written several EPICS releases ago.
A few minor problems did arise that forced us to generated an internal
beta release. We are now starting work to convert the par (the next
APS accelerator after the linac) to 3.13. If things go well we hope
to convert some other APS/ASD systems during the current shutdown.
We should be generating a new beta release soon. At that time
updated release notes and updates to the Application Developer's
Guide will be available.
In addition to fixing minor problems two major problems are being
addressed for the next beta release.
The first is that GDCT does not work correctly when linked against
3.13. It partially works but often crashes badly. Several users
reported problems. When Jim Kowalkowski looked at the problem we
realized that there were still problems with the static database access
library. The main problem is that it did not provide for macro
definitions in menu or link fields. We are currently testing and are
close to having things work properly. In addition John Anderson has been
working on a tcl/tk replacement for the original DCT. Both a working
GDCT and the new tcl/tk DCT will be available for the next release.
The other major problem involves the UDF (undefined) field. The problem
was originally reported by Tim Mooney. Before 3.13 it was not possible
to distinguish between a link never given a value and a link given
a constant value. This forced some output records with DOL fields
to always set UDF false while initializing the record. Since we
can now distinguish between null and constant links the init code
was changed. The result is that some records could have UDF set true
forever. Janet Anderson has reviewed all record types and fixed
the problem. We also had to change dbPutString so that when it writes
to the VAL field it sets UDF FALSE.
So just when will we declare an official 3.13? My feeling now
is that we should wait until the end the current APS shutdown.
When we start up we will have several major APS/ASD subsystems
on 3.13. The EPICS developer's will do everyting they can to make
this a success including building new internal 3.13 releases
whenever problems arise. At the end of this process
we should have a stable 3.13 release.
I want to thank everyone who has started using the alpha and beta
releases. It is extremely important that we have testing at a variety
od sites. The EPICS developers take all reported bugs seriously!!
Marty Kraimer
Prev: EPICS Meeting Notes from CERN 9-96 Bob Dalesio
Next: FRC5CE task stack sizes Peregrine McGehee
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Next: Re: R3.13 Update Marty Kraimer
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
