1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Enhanced vxWorks Variable support
To: EPICS tech-talk <[email protected]>
Date: Thu, 24 Oct 1996 18:21:59 +0100 (GMT)
I've recently completed some changes to William Lupton's enhanced vxWorks
Variable device support routines, including adding support for waveform
records.  The enhancements should be transparent as far as anyone using
either the original EPICS device support or William's modified version.
With the new version, if the variable name is an indirect reference, with
or without an array index (e.g.  *pVariable  or  *pArray[5] ) then the
indirection now occurs at record-processing time rather than record
initialisation.
Support for waveform records allows a C array of any of the standard types
to be imported into the database.  As with the support for strings, an
array index in the variable name controls how far into the array the first
element of the array is read from.
The new versions of the device support files are available at
	ftp://ftp.ast.cam.ac.uk/pub/anj/devSymb.tar.Z
For details of the functionality read William's comments at the beginning
of devSymbFind.c
- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+------------	WWW: http://www.ast.cam.ac.uk/~anj
Prev: Re: frc64/frc604RT performance Johnny Tang
Next: CapFast follies Bret Goodrich
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: frc64/frc604RT performance Noboru Yamamoto
