1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Finding out when "NOW" is in a sequence
To: Ron Chestnut <[email protected]>
Cc: [email protected]
Date: Mon, 21 Oct 1996 16:15:45 -0500
Ron Chestnut wrote:
> In sequence code, I need to check for an aged epics record value. I can get
> a record timestamp with pvTimeStamp, but I can't find a way to get the current
> time short of doing a pvPut,PvGet,pvTimeStamp sequence to another record.
> The function TsDiffAsDouble does nicely in calculating a difference in seconds.
> Does anyone have a good suggestion on getting the current time? (pvNow)
> /Ron Chestnut
you can use these:
TS_EXTERN long TSgetTimeStamp(int event_number,struct timespec* sp);
TS_EXTERN long TScurrentTimeStamp(struct timespec* sp);
Defined in drvTS.h
struct timespec has the same structure as TS_STAMP in tsDefs.h
Jim Kowalkowski
708/252-9410
[email protected]
Argonne National Laboratory
Advanced Photon Source - Accelerator Systems Division
Controls and Computing
Finding out when "NOW" is in a sequence Ron Chestnut
Prev: Finding out when "NOW" is in a sequence Ron Chestnut
Next: Re: Finding out when "NOW" is in a sequence Jeff Hill
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
