1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: R3.13.0beta2
To: [email protected]
Date: Thu, 10 Oct 96 14:38:32 PDT
I got base built, and managed to build extensions against it.  It all seems
to works, but I've noticed something unusual.
I'm using a slight modification of the examples database that was included
in the release.  (the only modification is to increase the range of values
generated by the calc record)  I've got a little dm (v2.2) screen with 3
monitors of different types looking at the aiExample record.  The calc
record is scanning 1/second and is forward linked to the ai record.
On the dm screen I would normally expect to see the value change once/second.
What I'm seeing is that frequently an update won't happen for 3 or 4 seconds.
When it does happen it jumps to the (apparently) correct number.
This is on a sun4 environment, SPARCstation 5, ioc is mv167/8mb, 25MHz.
AFAIK the network is lightly loaded.
Has anyone seen anything like this.  I could swear that before (on older
releases) I've always seen a nice smooth update rate when watching a changing
pv.  'Tis a puzzlement.
-bill
Prev: RE: ai/ao RAWL RAWH Gabor Csuka
Next: Re: R3.13.0beta2 Deb Kerstiens
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
