Argonne National Laboratory
1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Should ai, ao records have RAWH, RAWL?
To: tech-talk@aps.anl.gov
Date: Wed, 09 Oct 1996 15:00:07 -0500
Marty Kraimer wrote:
> Last week during a visit at DESY, Gabor Csuka
> suggested that the ai and ao records should have two additional
> fields RAWH and RAWL. The reason is that often it is possible
> to create common device support for a set of modules that differ
> only in the number of bits and/or polarity.
> I expressed concern that this opens door to an unlimited
> set of configuration fields. After discussion I had to agree
> that these two fields  are generic enough that perhaps
> we should add them. They would not impact any existing support
> but future support could use them.
> For example if a device is a bi-polar 12 bit adc the fields would
> be
> RAWH 2047 RAWL -2048
> If the device is a 14 bit unipolar adc the fields would be:
> RAWH 16383 RAWL 0
> Comments anyone?
I don't think records should have these fields.  The device
support module should know this information by reading a register
from the ADC board.  If there is a concern that someone may change
the operation of the ADC from bi-polar to unipolar while the system
is up, then the configuration registers of the ADC board can be
read each time the "read" function of device support is invoked.
I realize that things like PLCs that just spit values out over a
serial-type link are a problem.  One solution is to use the parm
field of the input link,  another solution is to use a "Config"
function in the vxWorks startup.cmd file (many Argonne device
support modules use this method).  Marty suggested that the PLC be
programmed to always send out 16 bit unsigned values - even if the
ADC is only 12 bit.
I have found that a user that is putting together a database that
takes input from an ADC does not want to manage a field that specifies
the raw range of the ADC.  The user may be using a cheap 12 bit
ADC in their test stand and have an expensive 16 bit ADC in the
actually running system. In this case the user probably does not want
to be concerned about changing the database when it needs to be loaded
into a different crate.
Many people put together generic processing routines that take
reading from ADCs and perform algorithms.  These databases can
be used with a large variety of ADCs.  It seems like a pain to
need to adjust fields for each different installation.
Jim Kowalkowski
708/252-9410
jbk@aps.anl.gov
Advanced Photon Source - Accelerator Systems Division
Controls and Computing
Re: Should ai, ao records have RAWH, RAWL? watson
Should ai, ao records have RAWH, RAWL? Marty Kraimer
Prev: EPICS software distribution Bakul Banerjee
Next: Re: Should ai, ao records have RAWH, RAWL? Nick Rees
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: Should ai, ao records have RAWH, RAWL? Jeff Hill
Next: Re: Should ai, ao records have RAWH, RAWL? watson
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
