1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: base release 3.13.0beta2 Problem
To: [email protected]
Date: Wed, 11 Sep 1996 09:27:49 -0500
A serious bug has been discovered in beta2.
The symptom is that the event task for
channel access links goes into an infinite loop.
If this happens it happens at iocInit time, i.e.
it should not happen after an ioc has successfully
initialized. Running spy after iocInit will show
if you experience this problem. The problem will
happen if any device or driver support delays
during the second phase of record initialization.
The beta2 bug report on the WWW has been updated.
It also tells you how to get a fix for this problem.
Marty Kraimer
Prev: agenda for the EPICS workshop Matthias Clausen DESY -MKV2/KRYK-
Next: Farewell to all John R. Winans
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
