1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: COMMUNICATION between EPICS and the Allen Bradley SLC 500
To: "Stephanie Allison (415)926-4534" <[email protected]>
Cc: [email protected]
Date: Fri, 30 Aug 1996 13:17:01 -0500
Stephanie Allison (415)926-4534 wrote:
> >* The Equipment Protection System (EPS) Status will be sent to EPICS via a
> >6008-SV1R VME Allen Bradley Remote I/O Scanner.  The scanner (i.e. a
> >6008-SV1R) actually talks to the SLC 500 remote I/O via a Direct
> >Communications Module (i.e. a 1747-DCM).
> The communication between the PEP-II high voltage power supply system and
> our RF EPICS system will be done in exactly the same manner.  We also use
> the 16 bit binary device support and set up the the database using the
> same formula as you.  In addition to binaries, we had the need to send and
> receive analog values from HVPS so we developed devABANALOG.c (very similar
> to devABBINARY.c) which provide device support for longins/outs and
> analogins/outs and assumes 16 bit raw values.
> This could be added to the standard distribution if anyone is interested.
We have a simliar need at APS and I was going to get ready
to add the support. Please send me your device support code (E-mail is OK).
I will add the support to 3.13.
Since AB PLC5s support IEEE float I will also add support for
passing this.
Marty
RE: COMMUNICATION between EPICS and the Allen Bradley SLC 500 415
Prev: RE: COMMUNICATION between EPICS and the Allen Bradley SLC 500 415
Next: Re: Hknitro60 + epics John R. Winans
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: iocLog - wishlist Gabor Csuka
