1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epics driver & device support for IRM
From: Matthias Clausen DESY -MKV2/KRYK- <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Thu, 22 Aug 1996 13:46:24 +0200 (MET-DST)
>We've looked at our future requirements, and while the IRM may not be a very
>good fit as it stands, the option of using a '162 with some of the large
>variety of IP cards available looks very interesting.
agreed
>Perhaps some discussion of creating a "standard model" for supporting IP cards
>under EPICS might be in order.  As the IP interface (including module
>identification) seems to fairly well specified, perhaps we could take advantage
>of that information in the system configuration and initialization process.
The idea of standardisation is always good - but this only works if the IP-modules can
really be identified by their ID. This rule is already broken by the IP modules designed
for the IRM. You have to manually specify the type which in our case is done through
environment variables in the startup command file.
Maybe we'll find some time during the next EPICS meeting to start the discussion over
coffee!?
Matthias Clausen
Prev: Re: epics driver & device support for IRM Gabor Csuka
Next: Re: rec/devSup advise needed Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: epics driver & device support for IRM Bill Brown
