1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Quality of the C code generated by the EPICS state notation compiler.
Date: Thu, 20 Jun 1996 10:16:29 +0100 (BST)
I have found the EPICS state notation compiler to be a very useful tool,
and I am using state notation code as the key part of the Core Instrument
Control System I am building for the Gemini 8m telescopes project.
The Gemini programming standard requires that all code submitted to that
project be compiled using and be acceptable to the "-ansi -Wall -pedantic"
options of the C compiler. Unfortunately, when the C generated by the
state notation compiler is compiled in this way it produces a whole stream
of warning messages, sometimes several pages in length. Here are a few
typical examples:
  Warning:  variable "DATUM_ON" is used but not declared.
  Warning:  variable "DATUM_OFF" is used but not declared.
  ../cics_st.st:191: warning: return-type defaults to `int'
  ../cics_st.st: In function `D_filter_ss_init1':
  ../cics_st.st:441: warning: control reaches end of non-void function
  ../cics_st.st: At top level:
  ../cics_st.st:508: warning: `return' with no value, in function returning non-void
  ../cics_st.st:510: warning: control reaches end of non-void function
  ../cics_st.st:515: warning: return-type defaults to `int'
  ../cics_st.st: In function `D_filter_ss_not_datumed':
  ../cics_st.st:1485: warning: `return' with no value, in function returning non-void
  ../cics_st.st:1487: warning: control reaches end of non-void function
  ../cics_st.st:1490: warning: return-type defaults to `int'
  ../cics_st.st: In function `exit_handler':
I find these warnings can quite easily hide genuine compilation problems.
Is it possible for the state notation compiler to produce code that will
generate fewer warnings (e.g. by declaring the type of some of the
functions the compiler complains are not declared and by adding a value to
"return" statements). Also, I think fixing these warnings now will lead to
more reliable code in the long term. Any comments?
Steven
Steven Beard
Royal Observatory                  Tel.   : +44 (0)131 668 8253 (direct)
Blackford Hill                              +44 (0)131 668 8100 (switchboard)
Edinburgh EH9 3HJ                  Fax.   : +44 (0)131 668 1130
UK                                 E-mail : [email protected]       (Internet)
                                   WWW    : http://www.roe.ac.uk/smbwww/
Re: Quality of the C code generated by the EPICS state notation compiler. Johnny Tang
Prev: gdct on Solaris Mark Rivers
Next: Re: Quality of the C code generated by the EPICS state notation compiler. Johnny Tang
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
