1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Vanishing OUTLINKS
To: Peregrine McGehee <[email protected]>
Cc: [email protected]
Date: Fri, 21 Jun 1996 15:10:07 -0500
Peregrine McGehee wrote:
> Marty Kraimer writes:
>  > Can you isolate the example to just 2 soft records and then send
>  > me the .db format database.
> Hmm. The original example had A as a LONGOUT record and B as a CAD
> record (from Gemini). I just tried it with B as both a LONGOUT and a
> LONGIN and it works!
I will make a wild guess about what is happening.
After the first time the CAD record is processed
it puts itself into a state such that it is not
processed by the longout record.
Does it change it's scan mechanism?
If it is active or disabled you should see
a message when TPRO is on.
Try nthe following:
reboot
Do a dbpr
"<cad record>",4
before first dbpf
after dbpf
after 2nd dbpf
Does anything make sense?
Marty Kraimer
Re: Vanishing OUTLINKS Peregrine McGehee
Re: Vanishing OUTLINKS Marty Kraimer
Prev: Re: Vanishing OUTLINKS Peregrine McGehee
Next: Re: Vanishing OUTLINKS Peregrine McGehee
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
