1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Vanishing OUTLINKS
To: [email protected]
Date: Fri, 21 Jun 1996 09:57:39 -1000
Marty Kraimer writes:
 > Can you isolate the example to just 2 soft records and then send
 > me the .db format database.
Hmm. The original example had A as a LONGOUT record and B as a CAD
record (from Gemini). I just tried it with B as both a LONGOUT and a
LONGIN and it works!
So this seems to be record type dependent.
Case I: (doesn't work)
	record(longout,"cp:if:mcs:dir") {
		field(DESC,"long output record")
		field(SCAN,"Passive")
		field(PINI,"NO")
		field(PHAS,"0")
		field(EVNT,"0")
		field(DTYP,"Soft Channel")
		field(DISV,"1")
		field(SDIS,"0.000000000000000e+00")
		field(DISS,"NO_ALARM")
		field(PRIO,"LOW")
		field(FLNK,"0.000000000000000e+00")
		field(OUT,"mcs:cmd:move.DIR .PP .NMS")
		field(DOL,"0.000000000000000e+00")
		field(OMSL,"supervisory")
		field(EGU,"units")
		field(HOPR,"0")
		field(LOPR,"0")
		field(HIHI,"0")
		field(LOLO,"0")
		field(HIGH,"0")
		field(LOW,"0")
		field(HHSV,"NO_ALARM")
		field(LLSV,"NO_ALARM")
		field(HSV,"NO_ALARM")
		field(LSV,"NO_ALARM")
		field(HYST,"0")
		field(ADEL,"0")
		field(MDEL,"0")
		field(SIOL,"0.000000000000000e+00")
		field(SIML,"0.000000000000000e+00")
		field(SIMS,"NO_ALARM")
		field(IVOA,"Continue normally")
		field(IVOV,"0")
	record(car,"mcs:cmd:move_car") {
		field(DESC,"CAR record")
		field(PINI,"NO")
		field(PHAS,"0")
		field(EVNT,"0")
		field(DISV,"1")
		field(ERSV,"NO_ALARM")
		field(PRIO,"LOW")
Case II: (works)
	record(longin,"test:b") {
		field(DESC,"long input record")
		field(PINI,"NO")
		field(PHAS,"0")
		field(EVNT,"0")
		field(DISV,"1")
		field(PRIO,"LOW")
		field(INP,"0.000000000000000e+00")
		field(EGU,"volts")
		field(HOPR,"0")
		field(LOPR,"0")
		field(HIHI,"0")
		field(LOLO,"0")
		field(HIGH,"0")
		field(LOW,"0")
		field(HYST,"0")
		field(ADEL,"0")
		field(MDEL,"0")
	record(longout,"test:a") {
		field(PINI,"NO")
		field(PHAS,"0")
		field(EVNT,"0")
		field(DISV,"1")
		field(PRIO,"LOW")
		field(OUT,"test:b.VAL .PP .NMS")
		field(EGU,"units")
		field(HOPR,"0")
		field(LOPR,"0")
		field(HIHI,"0")
		field(LOLO,"0")
		field(HIGH,"0")
		field(LOW,"0")
		field(HYST,"0")
		field(ADEL,"0")
		field(MDEL,"0")
		field(IVOV,"0")
Peregrine
Re: Vanishing OUTLINKS Marty Kraimer
Vanishing OUTLINKS Peregrine McGehee
Prev: Re: Vanishing OUTLINKS Marty Kraimer
Next: Re: Vanishing OUTLINKS Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
