1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Q] CAMAC Serial Driver
To: [email protected]
Date: Fri, 14 Jun 1996 10:10:52 -0600 (MDT)
>>I believe this hardware independence has been preserved. I have loaded the
>>latest EPICS CAMAC package onto an IOC which was running only vxWorks (and not
>>EPICS) and it runs fine.
>Not exactly my point.  Can you load EPICS with a CAMAC library from CERN
>with no modifications and then use (for example) a CES branch highway
>interface?
>Chip
I don't think there is anything in the CEBAF/LANL/Chicago EPICS CAMAC device
support which uses any of the "Implementation-Dependant" features of the ESONE
standard.  The exception to this is the card-specific lam-grader module I
currently include in the distribution.
It therefore should be possible to load (for example) a CERN Camac library and
run EPICS device support on top of it.
This, of course, is an as yet unproven assertion.
Eric Bjorklund				Voice: 505-667-6031
Los Alamos National Laboratory		Email: [email protected]
AOT-6 MS H820
PO Box 1663
Los Alamos, NM 87545
"The ugly side of the profession that James Baldwin was so intimately
familiar with."
Re: [Q] CAMAC Serial Driver watson
Prev: Re: EPICS port to Heurikon Baja47. Ric Claus
Next: CA documentation Carolyn Malloy
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: One button -> two actions with dm? Steve Lewis
Next: Re: [Q] CAMAC Serial Driver watson
