Argonne National Laboratory
1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: mv162 only
To: jemian@arev.uni.aps.anl.gov (Pete Jemian)
Cc: tech-talk@aps.anl.gov
Date: Tue, 11 Jun 1996 09:52:53 +0200 (MET DST)
Why not changeing the names ?
CONFIG_SITE: CROSS_COMPILER_TARGET_ARCHS=mv162 mv167
CONFIG_SITE: CROSS_COMPILER_TARGET_ARCHS=mv16x-lc mv16x
The confuesing is comeing of the target name, while
the target is mv167 - meaning a MC680X0 processor with FP
and the target mv162 - meaninig is a MC680X0 terget without FP.
but thera are a lot of mv162 boards with FP.
My suggestion changeing the target names, such as:
mv167 -> mv16x
mv162 -> mv16x-lc
> > We have some applications which run mv162s using the EPICS/VxWorks mv167
> > release.  Does anyone know any reason why this is a bad idea?  Obviously
so this is not a bad ide, this is the only way yet (without modification
a lot in config files :) )
> > it works, but are there any functionality differences?
> This is what I've been doing for some time.  That is, build for the
> mv167 and run it on the mv162.  No problems.
> Since I just installed a new system from scratch last week,
> I thought I'd find out what's the correct way to support the mv162.
> Consensus is, if the mv162 is not a mv162lc, then
> [1] build for the mv167 and run it on the mv162
> [2] edit config/CONFIG_ARCHS.mv162 and change the line
> 	ARCH_DEP_CFLAGS=-DCPU=MC68040 -msoft-float -DCPU_FAMILY=MC680X0
>    to
> 	ARCH_DEP_CFLAGS=-DCPU=MC68040 -DCPU_FAMILY=MC680X0
I don't suggest this, while maybe you have mv162 boards with and without FP
in the same time :)
Regards
Gabor Csuka
DESY, Germany
Re: mv162 only Pete Jemian
Prev: EPICS software distribution Bakul Banerjee
Next: Re: mv162 only Johnny Tang
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: mv162 only Pete Jemian
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
