> From [email protected] Mon Jun 10 08:56:27 1996
> Return-Path: <[email protected]>
> Date: Mon, 10 Jun 1996 09:53:01 -0500
> To: [email protected]
> Subject: Re: mv162 only
> Content-Length: 1104
> X-Lines: 38
> >Q: Why does this happen?
> >In file CONFIG_SITE, I set
> >CROSS_COMPILER_TARGET_ARCHS=mv162
> >since the only crate processor I have is a mv162.
> >Then I rebuilt EPICS R3.12.2 base.
> >Here's the output from when the crate boots.
> >-----------------------------% clip here %-----------------------------
> >ld < targetmv162/iocCore
> >undefined symbol: ___eqdf2
> >undefined symbol: ___gtdf2
> This is because you have 'soft-float' defined somewhere and are not loading
> the floating point emulation libraries that come with vxWorks. I don't
> know *how* you are supposed to load them... I don't use that stuff, but
> I suspect that if you build vxWorks for soft-float, they are built in.
> I also suspect that you have a board with floating point on it... are loading
> the vxWorks w/o soft-float (as you should for that board) and are just building
> EPICS wrong (for a soft-float environment.)
> >Q: Do I need to compile for BOTH the mv162 AND the mv167?
> >That is,
> >CONFIG_SITE: CROSS_COMPILER_TARGET_ARCHS=mv162 mv167
> Not that I am aware of.
> >Q: Is this a bug?
> Nope. It is a feature ;-)
> --John Winans
Yet one more comment on using EPICS for 162's which have floating point:
If you look at the difference between
CONFIG_ARCH.mv162 and CONFIG_ARCH.mv167 in the config directory the
only difference is
>portia:config% diff CONFIG_ARCH.mv162 CONFIG_ARCH.mv167
17c17
< ARCH_DEP_CFLAGS = -DCPU=MC68040 -msoft-float -DCPU_FAMILY=MC680X0
> ARCH_DEP_CFLAGS = -DCPU=MC68040 -m68040 -DCPU_FAMILY=MC680X0
So, if you designate your
you will by default get -msoft-float.
This happened to me when I was helping someone set up a system
with 162's which had floating point. I just
had them use epics for the 167 instead of the 162.
This may not be a bug, but I think it is misleading. perhaps the
config should make a distinction between 162LC and 162.
Rozelle
|Rozelle Wright Phone (505) 667-4804 |
|Los Alamos Natl Labs AOT-8 FAX (505) 665-5107 |
|PO Box 1663 MS-H820 Group Office (505) 667-6087|
|Los Alamos, NM 87545 email : [email protected] |
Re: EPICS on Baja. Tim Mooney
Re: mv162 only Tim Mooney
<1996>
Re: mv162 only John R. Winans
<1996>
