1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS on Baja.
To: [email protected]
Date: Mon, 10 Jun 1996 09:15:35 -0700
Re: port of EPICS onto Heurikon Baja.
We are continuing with the port of EPICS 3.12.2 onto the
Heurikon Baja boards. The first draft was to get
soft channel records running (no I/O). It was found
that an ai record runs 50 times faster on the baja
compared with a standard mv162 (no FP). This is the
figure Heurikon are touting.
Getting the I/O running over the VME bus is taking a little
longer. Main problems encountered with this so far are:
VME interrupts are not mapping to the CPU, this should just
be a matter of programming the VME64 chip.
I've had to reprogram the boot rom because the MIPS VxWorks BSP
waits for the VME SYSFAIL signal to extinguish before
it loads the kernel over the network. Unfortunately the
Xycom 566 ADC cards we have never release the SYSFAIL line!
I'll send the documented port to the EPICS release control team as soon
as it is fully running and tested.
regards,
Dave Barker.
LIGO
Caltech Pasadena
CA USA.
Re: EPICS on Baja. watson
Prev: fwd: a note from hurikon about performance John R. Winans
Next: Re: EPICS on Baja. Tim Mooney
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EPICS on Baja. watson
