1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: mv162 only
To: [email protected], [email protected]
Date: Fri, 7 Jun 96 18:40:45 CDT
> the mv162 has the 68LC040 CPU with no hardware floating point
> support.
> To run EPICS (which uses floating point calculations), you must have
> a VxWorks kernel with the software floating point emmulation installed.
> Epics needs to be built knowing that software FP is to be used, this
> is done using the -msoft-float compiler flag.
> Building VxWorks for software FP support requires the fpSoft040.c
> file for 5.1.1 and a new library file libMC68040gnuvx.
> The flag INCLUDE_SW_FP also needs to be set in configAll.h.
> hope this helps,
> Dave Barker.
Hmmm...
My VxWorks v5.2 does not have a file fpSoft040.c
Is this a difference between 5.1.1 and 5.2
or could it be a BSP option?
Also, my mv162 is a MVME 162-042.
Don't they have the floating point support built-in?
(It was left out on the LC to speed the 68040 chip to market?)
Pete
Re: mv162 only Paul Banta
Prev: mv162 only Pete Jemian
Next: new INST_IO vxWorks global variable device support William Lupton
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: mv162 only Paul Banta
