1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Is var_ptr in 1.8 same as pVar in 1.9 SNL ?
To: [email protected]
Date: Mon, 13 May 96 15:40:40 EDT
This mail is made of the recycled electrons
Mailer: Elm [revision: 70.85]
Do you know ...
Is var_ptr in 1.8 SNL same as pVar in version 1.9 ?
There are many sequencers using the reentrant option at CEBAF.
To access the user variables from the eacaped C code in SNL,
var_ptr has been used as a pointer to UserVar struct.
Now var_prt is no longer defined in version 1.9 SNL.
The existing sequencers developed in 1.8 SNL are not compatible
with 1.9 SNL.
Johnny
Johnny Tang     Voice: (804)249-7239  E-Mail: [email protected]
Continuous Electron Beam Accelerator Facility
12000 Jefferson Avenue, MS 85A
Newport News, Virginia 23606
Prev: Re: Converting a float to an integer in a calculation record. Tim Mooney
Next: GPIB driver under Force CPU40 CPU board. Noboru Yamamoto
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: bug in sequencer Rozelle Wright
