Bill,
On Tue, 30 Apr 96 11:18:06 PDT Bill Brown <[email protected]> wrote:
> When we do a co of epics from our repository, everything looks fine. However
> after we do the initial gmake from base/ the sub-directory base/rec/CVS and
> all its contents are GONE! This makes bad things happen when one tries to
> do a "cvs commit" or "cvs update."
base/rec should not be checked into CVS at all - it is recreated
every time you run gmake inside base/src/ascii. Your old base/rec
directory is renamed base/rec.bak, and a new directory is created to
hold the newly created *Record.h files. base/rec isn't the only
directory which is created at compile-time; it should be treated just
like the base/bin and base/lib directories.
Hope this helps,
- Andrew
O o ._ Andrew Johnson, Royal Greenwich Observatory
__\\_ Madingley Road, Cambridge, CB3 0EZ
__|ooooo|__ Tel +44 (0)1223 374823 Fax 374700
~~\_________/~~ WWW http://www.ast.cam.ac.uk/~anj/
VXI support Ric Claus
HP VXI Modules W. Stephen Syrett
<1996>
A bad thing happens when I build base/ Bill Brown
Re: A bad thing happens when I build base/ Bill Brown
<1996>
