1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: vxWorks variable device support
To: William Lupton <[email protected]>
Cc: [email protected]
Date: Mon, 15 Apr 1996 16:24:48 +0100 (GMT)
William,
On Fri, 12 Apr 96 13:55:41 HST William Lupton <[email protected]> wrote:
>  There is vxWorks global variable device support for ai, ao, longin,
>longout, stringin and stringout records. The vxWorks global variable is
>  I propose extending device support to make use of the INP and OUT
>fields and to use an INSTIO string to hold the variable name (36
>characters are available) plus to support a leading "*" character to
>force an extra dereference. If the field is not INSTIO, existing
>behavior will occur, so the change is upwards-compatible.
Good idea - we had an application where the existing name derivation was useless
so in the end we had to design it a different way, but it would have been nicer to
use vxWorks variables with INSTIO and a name unrelated to the record name.
>  One could also support trailing "[n]" or "+n" syntax to reference the
>nth element of an array or at a byte offset of n. Is this worth it?
IMHO the "a[n]" array syntax is worth it; "a+n" may be confusing because some
people might think you were providing C pointer arithmetic rather than a byte
offset.  What about "a-n", "a[n]+m", "a[n][m]" etc?  I'm not suggesting you
implement these, you obviously need to draw a sensible line.
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_      Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__   Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Prev: vxWorks variable device support William Lupton
Next: New EPICS Pages Intalled Jackie Wallis
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: vxWorks variable device support William Lupton
