1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Possible Problem with aao Record
To: [email protected]
Date: Thu, 11 Apr 1996 12:19:54 -0600 (MDT)
We have discovered what may be possible bug with the aao record.  The problem
appears to be in the "put_array_info" routine, which stores the number of
points to write in the NELM field of the record.  The problem with this that if
you write less than NELM points to the aao record,  any further connections to
this record get the new, lower, value of NELM (through "cvt_dbaddr" or
"get_array_info") and are no longer able to write as many points as the record
originally specified.
My questions are:
 o Shouldn't "put_array_info" be updating the NORD field instead of the NELM
   field? (if so, it means we should probably change the code in
   devAaoCamac.c as well).
 o What is the correct value, NELM (the capacity of the record) or NORD (the
   number of points actually written) to return from "cvt_dbaddr" and
   "get_array_info"?
 o (and, BTW...  shouldn't SIOL be defined as an OUTLINK on an aao record?)
					Eric Bjorklund
					AOT-6 (LANSCE Operations)
					LANL ([email protected])
Prev: Proposed stepper motor code modifications Ric Claus
Next: re: HTML tools Mark Rivers
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Remote Camera Control Jeffrey J. Gross
