1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Trial of New Epics Doc Pages
To: [email protected]
Date: Tue, 2 Apr 1996 14:34:33 -0600
ANNOUNCING!!!!
New EPICS Documentation Web Pages (Pre-Alpha-Release)
I have implemented a new set of WWW pages to make EPICS
documentation more accessible and manageable.  Please take a
minute and try them out for me, and let me know what you think.
http://www.aps.anl.gov/asd/controls/epics/EpicsDocumentation/WWWPages/EpicsFrames.html
Sorry the path is so long, but once it is official, it will
be moved up to the top level of the directory structure.
The pages will work best when viewed with a Netscape2.0-compatible
browser, as I am extensively using the Netscape 'frames'
capabilities.
A couple hints for using Netscape's frames feature:
- The 'BACK' button will not work like you expect it to.  It will
  not return you to the previous contents of the screen, it will
  take you back to the page you were at before you came to the
  EPICS documentation page.
- To return to the previous contents of a frame, click and hold
  the right mouse button.  A pop-up menu will appear with
  Forward-in-Frame/Back-in-Frame options.
- If a frame is too big/small put the mouse pointer on the line
  between the frames, click and hold middle mouse button and
  resize frame as desired.
Also, I need you to consider several questions:
1) APS is willing to be the repository of all EPICS and
   EPICS-related documentation.  The reasoning for this is to
   have one place where people can go for all their EPICS
   documentation needs.
     Question:  If you are a non-APS person and authoring EPICS
         documents, should APS provide a link to your document at
         your home-site, or should APS maintain a copy of the
         document here?  If links are your choice, are you going
         to be able to guarantee the stability of the link (no
         moving directories around, etc.)?
2) When APS has accumulated all the EPICS documents and
   established a stable documentation system, should the site be
   mirrored in Europe?  If so, where?  Any volunteers?  Anybody
   know how to do this?
3) In what format(s) should the EPICS documents be available:
   Hypertext, Postscript, Zipped-Postscript, A4-Postscript?
4) What about old versions of a document... should they be kept
   in the list of active documents?  Or, should they be moved off
   to an 'attic' area?  If moved to the attic, would the attic
   have to be web-accessible (which involves maintaining two
   document structures instead of just one)?
5) Who do I have to tell when I re-arrange the document world
   here on 'www.aps.anl.gov'?
   Part of this process is going to involve cleaning out all
   the old stuff that is sitting around and straightening out
   the spaghetti-like directory structure.  If you are using
   something here, linked to something here, or just want to
   make sure your something doesn't get deleted, let me know.
6) How many of you are _not_ using a Netscape2.0-compatible
   browser?
All questions, comments, suggestions welcome.
Jackie Wallis
Documentation Specialist
APS-ASD Controls Group
[email protected]
(708)252-6023
Re: Trial of New Epics Doc Pages watson
Prev: S: CapFast Symbols for mbb*Direct (fwd) Johnny Tang
Next: Re: Trial of New Epics Doc Pages watson
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
