1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Events lost, discard count was XXX
To: [email protected], [email protected]
Date: Fri, 1 Mar 96 10:03:18 MST
Gabor,
> I have see the following on my IOC console:
> -> 0xd89d60 (CA event): Events lost, discard count was 1646
> 0xd89d60 (CA event): Events lost, discard count was 1774
> 0xd89d60 (CA event): Events lost, discard count was 2
This occurs when a client is consistently consuming
less events per sec than the server is generating per sec.
There is enough buffering in the system so that
the client can briefly fall behind. However, if this condition is
sustained then the server will eventually discard events
for the client involved (other clients are not effected).
Possible causes (a particular type of client involved):
o client is synchronizing a slow activity with every event
	Some OPI client side tools avoid these problems by implementing
	a cache with an associated modified data tag for each
	PV that is monitored. CA event call back functions
	update this cache instead of performing the slow activity
	directly (ie drawing on the screen etc).
Possible causes (a particular host involved):
o client isnt given enough CPU
Possible causes (a particular network involved):
o events cant be communicated over the network as fast as the server
is generating them. A network path to the client might not exist
or it might be saturated.
Possible causes (most clients involved):
o scan rates for the records involved are too high (frequent)
o deadbands need to be set for the records involved
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Re: Events lost, discard count was XXX watson
Next: Latest CVS version Philip Taylor
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Is edd/dm still available for EPICS 3.12? Ying Wu
