1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: "dm" and Access Security
To: [email protected]
Cc: [email protected]
Date: Thu, 22 Feb 96 10:01:09 MST
Andy writes:
> Another requirement of the Gemini Project is to be
> able to dynamically change access to various records and
> fields. If my understanding is correct, you can do this by
> calling a special routine from a SUB record which re-initialises
> access security by re-reading the ACF.
> What would happen, under these circumstances, to a "dm" display?
> This change in access security could well mean that
> controllers which previously only had read permission now
> have write permission as well.
> Could "dm" be made to update dynamically? My feeling is that
> it could, if it were only displaying simple text like "Access denied"
> and didn't require redrawing of boxes with different colours.
> Andy
Dm is currently set up to get changes in access using a
CA callback that gets executed when access changes, so it
will be able to dynamically reflect the change.  Currently
it just ignores the information.  I hadn't anticipated
changes to access being really frequent, so I hadn't viewed
it as real performance issue.  I was planning to move from
"access" appearance to "no-access" appearance, etc. dynamically.
This could be fairly ugly if access will be changed really
rapidly.  Anyone planning to change back and forth faster
than once a second or so??  (Even that rate could drive the
viewer nuts!)
The change is easiest for controllers that move between
read/no write and read/write, since they're already basically
visible in a normal state.  Changing between no read and read
would be the biggest hit.
BTW, thanks to all for the input.  I'll mull it over and try
to write up a strawman.
Deb
Deb Kerstiens		[email protected]
Phone			(505)667-3396
LANL AOT-8,MSH820	PO Box 1663, Los Alamos, NM. 87545
Prev: Re: EPICS Access Security 415
Next: Re: EPICS Access Security Jeff Hill
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: "dm" and Access Security Andy Foster
Next: Re: "dm" and Access Security Jeff Hill
